So, looking at the datasheets for the SLP2040P from my A5000 PSU (Low 12v rail like my Mac Classic) which has a dead diode (There are two in the package), I found that the MBR2045CT has slightly improved specs over the original and should be fine as a replacement.
I would swear to god I checked the package dimensions on the datasheets as well as the electrical spec, but it seems my brain was mush at the time, and the sizes don't quite match
I'm confident that the part will work, it's of a slightly higher spec than the original, and I should be able to make it fit, so I can still get on with the repairs, but annoying nonetheless.
exxos wrote: Fri Nov 11, 2022 10:18 am
We all been there
exxos wrote: Fri Nov 11, 2022 10:32 am
...and plastic vs metal packages....different pinouts...bent legs vs straight legs..
Hell yeah...
It's almost impossible to find the right sized part on most suppliers' web sites.
stephen_usher wrote: Fri Nov 11, 2022 12:18 pm
You're not wrong.
I got an equivalent, the size is correct, the diode direction is correct and it has a better spec than the original.
Does it work? Does it heck!! You can hear the PSU 'ticking' as it tries to start, and as soon as I drop in the original, there it goes and works. Trouble is I still have the same issue and the 12V/5v rails start low and creep up like on the Mac Classic before I replaced the switching transistor. I'll just have to try and find the real thing.
What is annoying is that I can't find a schematic for the PSU, it'd solve a lot of problems if I could.
