1040 STF 6 chip TOS to 2 CHIP?
Upgrade or replace the ROM.
Gitbizy
Post by Gitbizy »
Any practical way of doing the above?
I'd like to go to a dual 1.04 / 2.06 setup but I have a 6 chip 1040.
Thanks-
Atari Stacy 4 w/T25 Accelerator. External Ultrasatan. Working on Stacy color monitor upgrade via RGB2HDMI.
Atari Mega STE 4/350. SCSI disconnected. External Ultrasatan.
Atari 600XL (in the progress of upgrading with U1MB, Sophia 2, etc.)
Atari 130XE with CSS Ultra Speed Plus OS 320kb
ATR8000 and a bunch of other Atari goodies
DoG
Re: 1040 STF 6 chip TOS to 2 CHIP?
Post by DoG »
What motherboard revision do you have?
EDIT: Some boards have jumpers that says 1M. Three of them needs to be moved/resoldered. You also need to have a 74LS11 fitted to combine the ROM signal if it is missing
EDIT2: Check here for motherboard revisions.
Be aware that to use 2.06 in an STF you would need additional address decoding.
What you're really talking about is dual TOS not 2 chip.
Converting from 6 chip to 2 chip TOS is relatively easy to do, you source a 2 chip ROM set, install and you would need to change the soldered ROM jumpers from 256KB to 1MB. It would give only one version of TOS though.
If on the other hand you do mean dual TOS, then the store has some boards, but as I said, without a decoder board, TOS 2.06 won't work in an STF.
Return to “ROM UPGRADES”
