FALCON030 which only boots on ROM
ylf22300
Post by ylf22300 »
Hi all,
I have a FALCON030 which boots only on ROM and does not allow access to the internal DD nor to the floppy disk drive!
once the desktop is displayed I see the icons of drives A and B but nothing helps whether I put a floppy disk with data or try to format a blank floppy disk, it is impossible to access the drive.
i've tried to replace the floppy disk but it's the same.
it seems that all IDE access are disabled :-(
does anyone have an idea???
thank you in advance for your help
Yann
PS : Sorry for my english, I'm from Britany ;-)
mikro
Re: FALCON030 which only boots on ROM
Post by mikro »
You will need to provide more information than that.
What does it mean that "all IDE access are disabled" ?
How "impossible" is to access floppy disk?
Is there any error shown? What hard disk driver do you use? Does SCSI work? Etc...
ylf22300
Post by ylf22300 »
here some information :
on screen A and B icons are displayed on desktop
after inserting an already formatted floppy double click on A (or B) icon the floppy driver led lightup
but after some second the following message is displayed :
drive A: not responding
check drive or insert floppy disk
of course i've tried this with more that 20 different floppy disk :-(
and when trying to format a floppy this message is displayed :
an error occurred while formatting or copying
the diskette may be protected or unusable
PS: messages are translated from French Rom version Falcon
concerning IDE HDD there is no C nor further D,E,... Icon present on desktop !
and of course no way to execute HDDriver without floppy drive
coonsgm
Post by coonsgm »
It sounds like the computer is trying to access the floppy disk. A couple of things to try:
1 - Replace the floppy with a known working one. I think the falcon drive is the same as a standard PC one (please correct me if I'm wrong here)
2 - clean the read and write heads with a cotton bud and IPA
ylf22300
Post by ylf22300 »
need to find another floppy drive, but not sure to find one easily!
so I'll try to clean floppy drive heads in a few days, but can you tell me what is IPA ? ;-)
coonsgm
Post by coonsgm »
IPA = IsoPropyl Alcohol
coonsgm wrote: Thu Sep 29, 2022 9:09 pm 1 - Replace the floppy with a known working one. I think the falcon drive is the same as a standard PC one (please correct me if I'm wrong here)
Yes.. But you have to change the drive ID. Its why I only generally recommend Sony mpf drives are they are simple to do and well documented.
But it begs the question as well., is the drive original or has someone already swapped it ?
ylf22300
Post by ylf22300 »
Hi, all
after cleaning the Floppy drive head the drive seems to operate correctly.
for the HDD drive i've replaced it with an IDE Compact Flash drive once the floppy was running. to initialize it with HDDriver 11.12 from floppy disk.
everything seeems to be OK now. :)
meanwhile ASAP I'll recap the PSU and install the clock patch from Exxos
Before you fit the clock patch run the tests to see if you actually need it in the first place. My machine didn’t.
ylf22300
Post by ylf22300 »
exxos wrote: Thu Sep 29, 2022 11:42 pm
I have found a Sony MPF 920 and I'll swap the original floppy with this one after modifying the sel0/sel1 strap.
the floppy in my Falcon is the original one when I bought it in 1993 !
