TF1260 extract cpu
ziosante
TF1260 extract cpu
Post by ziosante »
Hi,
I have a tf1260 with an 68LC060 and I want to upgrade with a 68060.
I tried with some plastic tools used for removing screens from smart phones, but with no luck.
How to extract the CPU? Any suggestions?
Thanks.
HigashiJun
Re: TF1260 extract cpu
Post by HigashiJun »
ziosante wrote: Fri Sep 16, 2022 7:52 am Hi,
Thanks.
Here you go:
Just a thought, is the CPU inserted into a socket or soldered to the board? I know, might seem a silly question but you never know.
ziosante
Post by ziosante »
PhilC wrote: Fri Sep 16, 2022 10:49 am Just a thought, is the CPU inserted into a socket or soldered to the board? I know, might seem a silly question but you never know.
socket
otherwise I would have talked about unsoldering not extracting
lilwashu
Post by lilwashu »
I used a flat headed screwdriver, working on each edge of the CPU one after the other by rotating it after sliding it between socket and CPU. One of the above tools is a better idea but I am far too tight fisted to pay the amounts generally asked for them.
ziosante
Post by ziosante »
lilwashu wrote: Fri Sep 16, 2022 1:32 pm I used a flat headed screwdriver, working on each edge of the CPU one after the other by rotating it after sliding it between socket and CPU. One of the above tools is a better idea but I am far too tight fisted to pay the amounts generally asked for them.
good, I'll try this way making attention do do not break the cpu
ziosante
Post by ziosante »
Using a screwdriver I was able to extract the CPU but with my great regret I discovered that the CPU is not a 68060 but a 68LC060 (has a MMU but no FPU)
It shows "MC68060RC50" with 71E41J mask but is an LC :cry:
foft
Post by foft »
There are a lot of fakes around sadly.
alenppc
Post by alenppc »
ziosante wrote: Fri Sep 16, 2022 5:32 pm Using a screwdriver I was able to extract the CPU but with my great regret I discovered that the CPU is not a 68060 but a 68LC060 (has a MMU but no FPU)
Classic reprint. If you bought it on ebay, send it back.
ziosante
Post by ziosante »
alenppc wrote: Fri Sep 16, 2022 8:23 pm
bought on Aliexpress, paid 300 EUR
I just opened a dispute to obtain a refund
Return to “TF360”
