To owners of 'short ST520/260', I need measurement checked
sporniket
Post by sporniket »
Hi,
As you could see on my member blog, I am porting the schematic of the 260/520ST a.k.a "short ST" into Kicad, and reconstructing the PCB is part of the process (helpfull as a proofreading process).
The reference material is a little bit unaccurate, and unlike the STE, I do not have measurements of the shape of the motherboard, and I have no real board to do the measurement myself. So if some owners of this model could check the measurement, it would help me.
Below are the various measurement I ended up with, using the scan of the PCB from the service manuals. Those are the measurements that I would like to confirm.
Capture d’écran du 2022-09-09 21-19-37.png (94.99 KiB) Viewed 1068 times
Thanks in advance.
Re: To owners of 'short ST520/260', I need measurement checked
I am the worst person in the world for measuring stuff. So take these with a pinch of salt and certainly not gospel :lol:
sporniket
Post by sporniket »
exxos wrote: Fri Sep 09, 2022 9:22 pm I am the worst person in the world for measuring stuff. So take these with a pinch of salt and certainly not gospel :lol:
Thank you. Even if there is some measurement errors, it confirms to me what I have to adjust, and gives me some clues about how much to adjust.
Of course, the more measurements I get, the better my adjustments can be.
sporniket
Post by sporniket »
After some adjustments here and there, I will go with that :
Capture d’écran du 2022-09-22 05-59-29 (copie).png (98.64 KiB) Viewed 951 times
