Trying to record some Amiga gameplay to my PC?
TheMadScientist
Post by TheMadScientist »
Hey. I hope someone can help me out. I'm trying to record some Amiga gameplay using a scart to hdmi converter and a usb to hdmi capture card. The sounds comes through great but the picture are not. The screen is grey and you can only very vaguely see the gameplay. Do anyone know what i'm doing wrong here ? Thanks
32Bits
Re: Trying to record some Amiga gameplay to my PC?
Post by 32Bits »
What are you using to do the recording? I use OBS and had similar issue recording game-play from my CD32 I would get sound sound only and a grey screen. I was using from a S-video to USB capture card. In OBS I had to set the video mode for the capture card to PAL. I'm it was defaulting to NTSC but my CD32 outputs PAL.
C128/A3000/CD32/A1200 -https://www.youtube.com/c/32Bits
The SCART to HDMI is for RGB isn't it? Sounds like you might just be seeing composite sync on the composite video pin of the SCART and the converter is just using that. Many current SCART/HDMI adapters are only composite video, very few now do RGB as they're designed for video recorders.
TheMadScientist
32Bits wrote: Fri Sep 02, 2022 8:05 pm What are you using to do the recording? I use OBS and had similar issue recording game-play from my CD32 I would get sound sound only and a grey screen. I was using from a S-video to USB capture card. In OBS I had to set the video mode for the capture card to PAL. I'm it was defaulting to NTSC but my CD32 outputs PAL.
I'm using StreamLabs, and i have an Amiga 500. The thing is that the grey screen also appears on my TV screen when i'm using the scart to hdmi converter, and my TV switches to PAL automatically.
TheMadScientist
stephen_usher wrote: Fri Sep 02, 2022 8:09 pm The SCART to HDMI is for RGB isn't it? Sounds like you might just be seeing composite sync on the composite video pin of the SCART and the converter is just using that. Many current SCART/HDMI adapters are only composite video, very few now do RGB as they're designed for video recorders.
I don't think its for RGB ? here's a link to the specs
https://www.av-cables.dk/scart-til-hdmi ... rce=google
Yeah, that's composite only. You'll have to use the Amiga's composite video output and audio and pass it to the SCART.
32Bits
Post by 32Bits »
TheMadScientist wrote: Fri Sep 02, 2022 8:25 pm
Ok if your getting the grey screen on the TV without the capture card then something is going on with the conversion from SCART to hdmi you need to be sure that the converter that supports RGB SCART.
Have a look at this article: "How-to-connect-your-amiga-to-a-modern-tv-capture-card-rgb-scart-to-hdmi-not-composite"
https://www.retro32.com/gaming/amiga/06 ... -composite
TheMadScientist
stephen_usher wrote: Fri Sep 02, 2022 8:40 pm Yeah, that's composite only. You'll have to use the Amiga's composite video output and audio and pass it to the SCART.
Thanks a lot for clearing this up much appreciated. I think that i'd rather buy a new converter than passing the composite through the scart, as i don't have all the needed cables. What should i be on the look for when looking for a new scart/hdmi converter ?
32Bits
Post by 32Bits »
There is a link to one that works on the page I linked to.
LiNKFOR SCART to HDMI Converter SCART + HDMI to HDMI Converter Adapter Supports RGB
TheMadScientist
32Bits wrote: Fri Sep 02, 2022 8:48 pm
Thank you very much, this is really helpful
