STE SOUND DAC CRACKLE & POP FIX
The latest tweaks and fixes to keep your machine running in tip-top shape.
Locked
The original investigation had many twists and turns and can be seen in this thread. Fixes below have been proven to solve the problems of a small number of machines so far of varying motherboard revisions. But more testing needs to be done by more people.
You can use STE DMA SOUND TEST PROGRAM to diagnose the problem as shown in the video below.
A simple solution is to solder some wires as short and as direct as illustrated by the white wires in the image below. A typical 1amp hook-up wire is fine. It does not make any difference if it is solid or stranded. But should be of a reasonable thickness at least.
The problem is mostly due to the bad usage of the 74F Series of logic chips. These are not good in noisy environments and actually cause noise due to their high switching currents. Also mix in Atari's typical poor grounding routing which compounds the issues.
Another proven fix Is to change them for a 74LS series chip.
One last proven fix is to lift the 5V power pin from the chip and connected back to 5V (from the cap) via a 40R resistor. For example.
You might also be interested in the original STE DAC NOISE FIX mod as well. This mod helps to resolve the classic "whistling" problem in one of the STE audio channels.
Mirror of the test program from github.
ste_dmatest-1.0.zip
(28.21 KiB) Downloaded 147 times
Re: STE SOUND DAC CRACKLE & POP FIX
I have moved posts to a new thread as this forum not a discussion forum.
viewtopic.php?f=29&t=5685
Locked
Return to “TWEAKS & FIXES”
