7406 and Floppy Fix
PeckPeekPoke
7406 and Floppy Fix
Post by PeckPeekPoke »
From what I've attempted to glean from photos, here is a sketch.
Could someone verify this?
Besides the 10kSil added to the WD1772, when adding resistors to fix floppy performance; on the 7406, there should be five 100k resistors wired from the pins coloured red in the drawing, (2,4,6,8,10) all terminating together at pin14.
Is this the correct ? :?
FOR GREAT JUSTICE. TAKE OUT EVERY ZIG
800xl+U1mb, STfm, STe, 030
Re: 7406 and Floppy Fix
This topic has all the info.
https://exxosforum.co.uk/forum/viewtopi ... =17&t=1395
PeckPeekPoke wrote: Wed Jun 22, 2022 4:56 pm Besides the 10kSil added to the WD1772, when adding resistors to fix floppy performance; on the 7406, there should be five 100k resistors wired from the pins coloured red in the drawing, (2,4,6,8,10) all terminating together at pin14.
Yep sounds correct. But 1k not 100k.
PeckPeekPoke
Thank you! 8-)
