Hi All,
I normally use Mechanic UV curable solder mask and a cheap Chinese UV lamp (that takes AGES to cure the soldermask!).
I wondered what you guys use/recommend for both the soldermask and the UV lamp to cure it? I'm looking for the best/quickest solution that doesn't take ages to apply/cure?
Thanks!
KbJ
What UV solder mask and cure lamp do you recommend?
Re: What UV solder mask and cure lamp do you recommend?
I'd be interested too as I have been using clear lacquer and allowing it to cure, but I'd rather go for proper green stuff.kbjunkie wrote: Fri Jun 10, 2022 12:35 pm Hi All,
Thanks!
KbJ
I used to use clear nail polish - and that seemed to work just fine..rubber_jonnie wrote: Fri Jun 10, 2022 1:12 pmI'd be interested too as I have been using clear lacquer and allowing it to cure, but I'd rather go for proper green stuff.kbjunkie wrote: Fri Jun 10, 2022 12:35 pm Hi All,
Thanks!
KbJ
The better half doesn't buy it anymore though, so I can't steal it
Haha, lolkbjunkie wrote: Fri Jun 10, 2022 2:02 pmI used to use clear nail polish - and that seemed to work just fine..rubber_jonnie wrote: Fri Jun 10, 2022 1:12 pm
The better half doesn't buy it anymore though, so I can't steal it![]()
