Bus error handling problem
I honestly cannot remember who wrote this routine...
EXXOS_BusErrorTest:
	move.l 		bas_params(pc),a0		; a0 = basic variable ptr
	move.l		(a0),a1				; a1 = basic variable (address to test)
	move.l		sp,d2				; d2 = old stack pointer
	move.l		$8,d1				; d1 = old berr handler
	move.w		#.berr-EXXOS_BusErrorTest,d3	; d3 = err handler offset
	lea		EXXOS_BusErrorTest(pc,d3.w),a2	; a2 = err handler absolute address
	move.l		a2,$8				; set new berr handler
	move.l		(a1),d0				; read from address
	move.l		d1,$8				; restore berr handler
	move.l		#1,(a0)				; return 1
	rts
.berr:
	move.l		d2,sp				; restore stack to before berr
	move.l		#0,(a0)				; return 0
	rts
Maybe someone have some ideas as to what is going on with it. IIRC was working when I would test a RAM location, basically because that location is used to returned a value back to BASIC code.
So I did a test routine where I could return to separate values by doing this..
	move.l 		bas_params(pc),a0		; a0 = basic variable ptr    6 ?
	move.l		(a0),a1				; a1 = basic variable (address to test) FF8964
 	move.l		#1234,(a0)			; return 1234 in X&
	move.l		#5678,4(a0)			; return 5678 in Y&
	rts
And this correctly returns the value to BASIC.
So I make the assumption that return 1 and return 0 get changed from #0,(a0) TO #0,4(a0) as that is what worked in my test routine.
However something has broken in the bus error handler and I have no idea what. I thought it was down to those code changes but even if I comments them out the handler crashes :(
If I simply put a RTS the start of the code then things don't crash. So definitely wrong with that bus error handler routine somehow :shrug:
Re: Bus error handling problem
When I call the routine I have been passing the actual address as a parameter EG:
 t&=&HFF8964
  Y&=66666
 call loc testcode&,EXXOS_BusErrorTest,t& ,varptr(Y&)
Which bomns out.
But passing the RAM pointer to the variable doesn't crash, but it returns 0 regardless of it the address is valid or not.
 t&=&HFF8964
  Y&=66666
 call loc testcode&,EXXOS_BusErrorTest,varptr(t&) ,varptr(Y&)
Must be something else broken somewhere as if I copy the working code into the BUSERROR routine and just RTS early, it doesn't return #1234 :WTF:
FFS!
I used t& as a variable and it NEVER returned a value. I changed it to X& and now its starting to behave.. and t& isn't even used anywhere in the program :WTF: Feking bonkers faults again :pullhair: :headbang:
mrbombermillzy
Post by mrbombermillzy »
Are we good now then?
Sooo..
STEEM - no Flashyclock
Real hardware with FC
So no feking idea why hisoft basic didn't like that variable name. I hate computers!
:comp:
and proof..
It's not just because its lower case either. Only possible thing is if t& is some internal thing :shrug: eitherway, waste 2 days just working that out :roll: :headbang:
Glad you've got it sorted out.
Since you're doubtlessly feeling completely better and not at all sore about it any more, can we now go back to taking the Gipsy Kiss out of you for using a Noddy language?
Too soon..?
Badwolf wrote: Tue May 17, 2022 11:11 pm Since you're doubtlessly feeling completely better and not at all sore about it any more, can we now go back to taking the Gipsy Kiss out of you for using a Noddy language?
:chairsmack:
It's always me which finds bonkers bugs in stuff regardless of what I use :roll: It's not like I even code much of anything :roll:
There is still something odd going on :roll:
Would this code work for WORD or BYTE access ? I can peek a byte or word in STOS and I get a number back, but a LONG I get BERR. Fair enough. But this code looks like it deals with longs ? So would that screw up WORD access checks ?!
	move.l		#1,4(a0)				; return 1
	rts
.berr:
	move.l		#0,4(a0)				; return 0
	rts
OK so doing
move.w		(a1),d0
Seems to work now..
sporniket
Post by sporniket »
It looks like accessing a1+2 does trigger the error handler then ?
