Has there been a dual TOS PCB for a Mega STE made?
I'm going to put mine to PP's 2.16 and while he mentioned that he has a MSTE compatible version of 1.62 and I have said not for now I'm wondering if I might as well get the bits in and do it.
Mega STE dual TOS?
Re: Mega STE dual TOS?
Not as far as I am aware no. I do not produce much items past the STF series.
There are probably hacks for it about somewhere using larger ROMs and lifting address lines to switch etc
- Velociraptor
Yeah that makes sense. The MSTE needs MSTE ROMs so you'd not be able to use it with anything before the first MSTE one 2.05 - well unless you used a modified one.exxos wrote: Mon May 02, 2022 12:13 pm Not as far as I am aware no. I do not produce much items past the STF series.
Ta!
- olivier.jan
Grab a pair of SST39SF020, flash both TOS, lift pin 30 (a17), solder a pull-up to 5v and a switch to ground linking both pins and you’ll have a dual TOS.
Retro stuff
