Having finally come to a conclusion as to why my visually impaired 600XL had a shimmer to the screen (https://www.exxosforum.co.uk/forum/viewt ... =18&t=5265) and realising that I'd made a mistake because there are no specific 600XL install instructions for the VBXE and I'd figured it out wrong, I thought the best thing I could do was to point them out so others who find themselves in the same boat can at least hopefully find this or my other article and get around these problems too.
So what are the gotchas?
Firstly, there are differences in IC numbers. This is relatively minor, since the install guide does refer to the chip type, so even if the U number doesn't match directly, identifying the ICs is still quite easy, but just be aware of it.
The second gotcha is what happened to me. Shown below is the 3.5Mhz oscillator circuit on the Atari 800XL:
You can clearly identify the crystal, Y1 and the rest of the oscillator circuit components, and the instructions state to remove Q8 and R110, which disables the oscillator by removing a key component, Q8.
However, on the 600XL, Q8 is a completely different transistor and not part of the oscillator circuit, though still part of the video circuit.
Looking at the 600XL circuit below, we can see that physically it looks much the same as the 800XL 3.5Mhz circuit, and schematically it is:
However the transistors in the circuit are labelled Q2 and Q3 and not Q8 and Q9.
Looking at the photos, it's kind of obvious now, but the upshot is, if you don't remove Q2 on the 600XL, the oscillator circuit remains live, and you end up with a harmonic between that oscillator and the 3.5Mhz clock picked off the 74LS74, which gives you a shimmery screen as per this video: https://www.youtube.com/shorts/5LpZocVyeRI
So in summary, when installing VBXL on an Atari 600XL, remove Q2 instead of Q8, and remove R49 instead of R110.
Then complete the wiring as described in the original install guide.
Hope this helps somebody else who may have misinterpreted things the way I did.
Atari 600XL VBXL installation gotchas
