TF1260 MMULib
Lamaman1971
TF1260 MMULib
Post by Lamaman1971 »
Hi Folks, after reading through John's guide on the 1260 I understand I need to install the MMULib - but wanted to ask about the installer options and what I should be selecting to correctly complete the installation on OS3.2 - its asking me questions that I am not sure what the optimal answers are - aside from the defaults!
Cheers
matt020
Re: TF1260 MMULib
Post by matt020 »
Ok, what questions are you being asked that you are unsure about. Post them up here...
Lamaman1971
Re: TF1260 MMULib
Ok, I'm installing this on 3.2.1 to accommodate an LC TF1260 :
1. Do you use a Phase 5 accelerator board : I assume the answer is a resounding "No"
2. Do I have an older ACA Board : Again, I assume the answer is "No"
3. Do I have a GVP 040 or 060 Board : Again, "No"
"Please pick the MuTools I want to install"
I assume just the defaults - MUFastROM, MuScan and MMU.guide (because I will be reading that)
"Shall I run MuFastRom on Startup?
Who knows - probably yes as it has the word "fast" in it and who doesnt like that eh?
"Run FastIEEE on startup"?
Again, it says fast. However, from experience there is nothing fast about the IEEE.
Hope that explains things a wee bit better!
supaduper
Re: TF1260 MMULib
Post by supaduper »
Yes go with what you have selected
Yes too with Mufastrom as it will map your rom so a speedup !
FastIEEE is already suported in later Amiga OS so it will not matter even if you select it
Re: TF1260 MMULib
This is exactly what I tell my parents to do when installing anything, no matter what it is "yes yes yes yes thanks good ok" :D
