Build a Gotek&OLED into a Short-ST
WARNING: CONTAINS CASE-MODDING, LOOK AWAY IF YOU DO NOT LIKE!
Hey all, as part of constantly modding my 'ultimate short-ST' I wanted to integrate a Gotek. In this I used a Flash floppy drive I bought from Simulant tech (UK) And integrated it with the external ST floppy kit sold by 5voltsupply (USA)
Links:
5voltsupply
Simulant
VIDEO OF IT WORKING CLICK HERE
PHOTOS OF MAKING IT:
1. put ext and gotek together.jpg (213.49 KiB) Viewed 3093 times
2. yeah that should work.jpg (277.51 KiB) Viewed 3093 times
3. ok it fits.jpg (225.35 KiB) Viewed 3093 times
4. might need to shorten pcb.jpg (381.62 KiB) Viewed 3093 times
5. pcb shortened.jpg (413.27 KiB) Viewed 3093 times
6. need to reverse the connector.jpg (405.83 KiB) Viewed 3093 times
7. connector reversed.jpg (384.78 KiB) Viewed 3093 times
8. usb extension inside.jpg (258.17 KiB) Viewed 3093 times
9. usb extension outside.jpg (198.52 KiB) Viewed 3093 times
10. lets glue the stands.jpg (406.37 KiB) Viewed 3093 times
11. stands glued.jpg (227.61 KiB) Viewed 3093 times
13. gotek in place.jpg (377.27 KiB) Viewed 3093 times
14. test it works with oled.jpg (392.16 KiB) Viewed 3093 times
15. hey that oled fits ok.jpg (295.71 KiB) Viewed 3093 times
16. mark out the oled.jpg (309.8 KiB) Viewed 3093 times
17. oled rough cut.jpg (285.8 KiB) Viewed 3093 times
18. smooth it out.jpg (269.85 KiB) Viewed 3093 times
19. rear oled.jpg (292.66 KiB) Viewed 3093 times
20. whole thing.jpg (397.82 KiB) Viewed 3093 times
21. sides.jpg (326.53 KiB) Viewed 3093 times
mrbombermillzy
Re: Build a Gotek&OLED into a Short-ST
Post by mrbombermillzy »
I completely applaud what you've managed to cram into that tiny little casing so far @Steve. :dualthumbup:
Cheers @mrbombermillzy ;)
Looks good to me @Steve. I'm planning to do something similar but slightly different once I get time
HigashiJun
Post by HigashiJun »
Nice job, Steve !
Thanks guys!
Just added an overview of the machine as it is right now:
Example of image output quality over hdmi:
coonsgm
Post by coonsgm »
Love it! Can you share a how-to on the RGB to HDMI implementation? Would love to see how you did it. Or point to another thread. I've looked into it a bit and found the github a bit confusing.
coonsgm wrote: Tue Feb 22, 2022 4:52 pm Love it! Can you share a how-to on the RGB to HDMI implementation? Would love to see how you did it. Or point to another thread. I've looked into it a bit and found the github a bit confusing.
It's plug'n'play m8, you can buy yourself a built-up unit, check this reply I posted to microman recently:
https://www.exxosforum.co.uk/forum/viewt ... 166#p80424
