Is there -12v conversion on H5?
Maybe a silly question, but I need -12v for a Vofa. If there isn't a converter could someone please advise the easiest method for me to build my own little converter? Thank you
Re: Is there -12v conversion on H5?
Is something like this suitable?
https://www.amazon.co.uk/Module1-25V-Positive-Negative-Regulator-Adjustable/dp/B07MLS4MV4
Cheers
Cheers
Assume so. Why does stuff need -12 anyway ?
frank.lukas
some Graphiccards need only +5V but some also +12V and some need -12V too. On a original ST you can use the -12V for the serial port or maybe a max232 ...
Ok cool thx
@exxos Chris as you know I struggle to read data-sheets, I am wondering if putting +12v into the LM337 is the most efficient way to have it output -12v? (of course the device has an adjuster, I just want to know the most efficient input voltage)
Thank you,
https://www.ti.com/lit/ds/snvs778e/snvs ... 4390299097
Thank you,
frank.lukas
... on the Panther/2 slot pcb is a MAX232 (feed from +5V) from which the +12V and the -12V are taken for the graphics card.
You can't... It's a negative regulator not a voltage generator .. Depending on how much current you want, switched capacitor converters might be a simple solution. But there be modules from China doing this kinda stuff anyway.Steve wrote: 09 Feb 2022 17:55 @exxos Chris as you know I struggle to read data-sheets, I am wondering if putting +12v into the LM337 is the most efficient way to have it output -12v? (of course the device has an adjuster, I just want to know the most efficient input voltage)
@exxos Sorry I thought earlier on you said you assumed that device would work for me (I've bought it and am testing it now) So this won't convert positive to a negative 12 for me then?
Oh sorry thought that modules was the converter but that's a regulator board now I look closer. I would just look on aliexpress for converter modules.
Or look at the STFM circuit as it has one.
