My STe came with no reset button button - I couldn't find a 3D one to print so knocked this up in openscad - should tightly snap fit *IF* printing with highest quality/smallest/finest layers you can and your extrusion amount (Material > Flow) is just right (calculated mine to 95.0 in Cura for my Ender Pro 3) as the margins are very fine.
Reset button on mine is 2.8mm square - so if yours isn't this won't help!
If your machine isn't calibrated or if it's too tight I would suggest knocking it back the Flow 1 at a time and reprinting (obv. it's tiny and only takes a few mins to print so not a major hassle) as this will fractionally increase the internal diameter of the snap bits
- [also it sticks out about 1 mm longer than the original]
Ste reset button button
