16Mhz Booster 2021 edition & Vofa stability
About the ST 16MHz simple booster.
Locked
Hi all,
Recently been playing with Exxos 16mhz booster in my short-ST that has a Vofa. With the Vofa in it was crashing (random amounts of bombs at different times) I took the Vofa out (Vofa is an ET4000 display adaptor in case you don't know) and the system was stable. The machine had all the mandatory fixes, so I was wondering what I could do that I hadn't already done to help stability.
I remembered that I had 'upgraded' the RAM line-driver chips to 'F' types after reading information on Atari-forum where it was recommended for the PAK CPU upgrade boards, 'F' types are faster than the original 'LS' types. I then did some searching and saw in this thread: https://www.exxosforum.co.uk/forum/viewtopic.php?t=254 - Exxos said:
LS being slower acts as a noise filter. F series is fast enough to react to the noise and will cause glitches and oscillations.
So I took out the F types, put the LS types back in and now all is stable.
Just writing this for others just in case somebody else hits this issue in the future...
Re: 16Mhz Booster 2021 edition & Vofa stability
Thanks for posting this.
I did a lot of tests on those "F" types as the "usual crowd" was saying they were better a while back. While they do have their uses, placing them in a STFM and/or MEGA ST only resulted in problems.
frank.lukas
Post by frank.lukas »
You can try ALS Types ...?
Sorry Frank I haven't got any on hand.
Locked
Return to “ST 16MHz BOOSTER 2021”
