exxos wrote: Fri Jan 14, 2022 11:06 am
16Mhz CPU only. 16MHz only when /AS is high.
Even if you take the assumption that ROM is running faster (it isn't in those tests) going to 50MHz where ROM speed is still 127%, the figures jump up again anyway. So its not down to ROM speed up.
In your 16MHz result the ROM is benchmarking there at 127%. Also yours isn't using the blitter (which is, of course, still 8MHz on mine), so your relative percentages will be higher.
I did have a very similar figure in one of my earlier tests (126 to 127% on ROM and 189 to your 193% on CPU). If we look at the VDI Graphics Test (less blitter), again it's close (130 to your 131%) when the ROM speed percentage goes up.
- Screenshot 2022-01-14 at 12.34.11.png (804.37 KiB) Viewed 3206 times
I actually intentionally disregarded that switching logic as I thought it must be stealing a cycle from the ROM somehow and might be unstable. Now I'm intrigued as to where that ROM figure comes from. This was obviously a very quick hack so I didn't get the logic probe on it.
We can look at relative figures, to take that ROM factor of the equation:
For the VDI graphics test (seemingly the most cpu intensive display test), I got a 9% speed increase from doubling the CPU clock. You go from 131 to 150%, a 15% speed increase, when tripling the clock (16 to 50).
So even allowing for the different ROM access times, the CPU effect on desktop use is shown to be pretty marginal, I reckon.
I think my conclusion that the ROM figure is where most of the display improvement comes from, particularly when blitter is enabled, is therefore fair.
PS. FrontBench never shifted from ~940 frames with all the different rom speed measurement (I went up to full 16MHz access to the ROMs). That's not surprising as it's primary a measure of RAM speed with a little bit of CPU thrown in.
