amiga 500+ help
thecaver99
amiga 500+ help
Post by thecaver99 »
i've just been given an amiga 500+ rev 8a board
when powered up i get a grey screen and power led flashes
i've made a diag rom and replaced the kickstart with it but no difference
i've swapped most of the ics from my working a500 apart from the agnus as my other 500 is not the plus.
i'm leaning towards the chip ram, i've ordered 10 x 20 pin sockets as i have a spare 1.5mg ram expansion with 12 ram chips that should work in place of the chip ram.
not sure what else to look at apart from buying a replacement agnus for it
when powered on the caps lock led lights no flashing, gotek powers up but no activity (or on original drive) and the power led flashes with grey screen no other activity
Re: amiga 500+ help
thecaver99 wrote: Tue Dec 28, 2021 7:32 pm i've just been given an amiga 500+ rev 8a board
Stop. Before doing ANYTHING get DiagROM. Either burn yourself a copy to a 27C400 or get one off eBay. It will tell you exactly whats wrong.
thecaver99
Re: amiga 500+ help
If you read my post, i've already said I have diagrom burned already and there is no difference
thecaver99
Re: amiga 500+ help
But thanks for replying
When diagrom is in it does exactly the same thing there is no difference what so ever
Re: amiga 500+ help
thecaver99 wrote: Tue Dec 28, 2021 8:34 pm But thanks for replying
DiagROM will work with no ram. So use the serial output. If DiagROM is completely dead you have something simple like a clock line fault or a broken trace.
thecaver99
Re: amiga 500+ help
Didn't think of that will dig out my serial link bits that used with my atari diag cart and hook it up, thanks
thecaver99
Re: amiga 500+ help
just run diag rom and captured the serial and at the end
Write: $AAAAAAAA 10101010101010101010101010101010
Read: $FFFFFFFF 11111111111111111111111111111111 FAILED
Write: $55555555 01010101010101010101010101010101
Write: $F0F0F0F0 11110000111100001111000011110000
Write: $0F0F0F0F 00001111000011110000111100001111
Write: $0F0FF0F0 00001111000011111111000011110000
Write: $00000000 00000000000000000000000000000000
NO Chipmem detected
- Parallel Code $fc - Trying to find some fastmem (as no chipmem found)
- Parallel Code $fb - Memorydetection done
- Parallel Code $80 - NO Chipmem detected
- NO MEMORY FOUND - HALTING SYSTEM
looks like i have no chip ram
Maximilian
Re: amiga 500+ help
Post by Maximilian »
Battery damage?
thecaver99
Re: amiga 500+ help
Just looking at the service manual and there are 3 x 74f ics that service the chip ram, might remove them and check them
thecaver99
Re: amiga 500+ help
No battery damage at all the board is clear and the battery was removed before it leaked by looks of it.
I e had a good look at the board where the battery was and no signs of corrosion and no green anywhere on the ics or other components
