Order impossible
Sinis
Order impossible
Post by Sinis »
Hello !
I would like to check out and there is a problem since this morning :
I wand to give money ! I want to pay ! I want to order ! :)
Thank you
Re: Order impossible
I think this is relating to a store change I did a few days ago... https://www.exxosforum.co.uk/forum/viewt ... =90&t=4931
Thanks for the report, I will go check the error logs and see what I screwed up..
@Sinis Please try doing your order again and hopefully it will work this time.. ?
Sinis
Post by Sinis »
@exxos Same bug.
It comes just after clicking on "Complete order" :
View Basket / Checkout / "Complete order", when you have the "shipping address" on the left of the screen.
This is now fixed.
I really don't understand the problem, because I have been using version 3 of my store code on my V2 store.. BUT the changes I made were on V3, but the file I did a binary comparison on it before making changes to make sure I was not going to break V2 system, and other than three lines which were basically comments, there was no changes whatsoever. But that file with the comments in malfunctions even when I removed those three commented lines. So I just went back to the original V2 file, made the changes I did last week again, and now it is working.. So I'm basically sat puzzling what the differences between the working and not working file :stars:
Was line 3 it was tripping up on. :shrug:
Sinis
Post by Sinis »
@exxos Yes, it's good!
Order ok!
...because I spent a LOT of time helping you (about 3 minutes :lol : ) I know you'll send the order as soon as possible : I should receive it tomorrow :)
On a more serious note, if I can help you, it would be my pleasure.
Sinis
Post by Sinis »
...perhaps not a problem regarding the file's content, but the file itself : rights and permissions ? Ok on the "old" file, Ko on the new one.
Just an idea.
Sinis wrote: Mon Dec 13, 2021 4:06 pm ...perhaps not a problem regarding the file's content, but the file itself : rights and permissions ? Ok on the "old" file, Ko on the new one.
Just an idea.
I don't know, because it was a error in the logs at lines 3..
PHP Warning:  Unterminated comment starting line 3 in /var/www/html/atari/store2/checkoutxxxxxx.php on line 3, referer: https://www.exxosforum.co.uk/atari/store2/
The file must have been running.. But that was the only change in the file from the previous file.
Just goes to show how even when you take precautions to make sure you are editing the right stuff.. Things still can go wrong :( It is why I did a binary comparison on the file before I started making changes, to make sure I had not change anything else between V2 and V3 store files..
Do not like it when things do not add up :cry: There is even similar comments further down the file anyway .
:dizzy:
I recall you mentioning the other day that PHP's parsing was a bit skew whiff -- tokens matching substrings of function names, for example.
Is it possible PHP treats "/ <space> *" the same as "/*", hence it looks like the whole file past line 3 is commented out?
derkom
Post by derkom »
Badwolf wrote: Mon Dec 13, 2021 5:17 pm Is it possible PHP treats "/ <space> *" the same as "/*", hence it looks like the whole file past line 3 is commented out?
It certainly shouldn't. When I stick this on my own server...
<?php
// this is a test comment
// *** this is a second test comment
/* this is a third test comment
phpinfo()
...I don't get an error until the third comment.
