TF1230 IDE - Second Drive
Lamaman1971
Post by Lamaman1971 »
Hi Folks,
I've tried to connect up a second drive to my Amiga using the TF IDE, a CF adapter and CF card (partitioned and formatted in WinUAE). When I plug in the CF card into the header on the TF1230 the Amiga will not boot - which is strange as I have no expectations of booting from the TF (until Steve's modified kickstart roms arrive) so was just hoping to boot from the A1200 IDE and then use the extra TF IDE as storage. Any ideas?
Re: TF1230 IDE - Second Drive
It’s v drive dependant. You might need a buffer
Lamaman1971
A buffer?
alenppc
Post by alenppc »
Lamaman1971 wrote: Wed Dec 01, 2021 5:10 pm Hi Folks,
Sounds like you plugged the cable backwards. Also make sure you're not using the VB.x CF adapters.
sparx
Post by sparx »
alenppc wrote: Wed Dec 01, 2021 6:40 pm
I currently have this exact same issue - it's caused by using eproms or emu's, If I switch back to 'stock' 3.0 roms I can boot and use both ide cf cards.
I have 2 TF1230's here, only happens with one
