Shapeshifter not work with IDE TF1260
hardgb
Post by hardgb »
I have a problem but first I apologize if I'm posting in the wrong place...
I'm using TF1260's IDE port and it has a great transfer rate but I noticed that after using this IDE I couldn't use Shapeshifter anymore. The screen freezes right after the shapeshifter tries to load MacOS. But when I use the A1200 IDE again the emulator works again.
Does anyone know how I can solve this problem? :(
Higgy
Re: Shapeshifter not work with IDE TF1260
Post by Higgy »
@hardgb are you overclocking? Does it still freeze at 50Mhz?
There is a known issue with the TF1260 IDE when overclocking.
arkadiusz.makarenko
Post by arkadiusz.makarenko »
hardgb wrote: Wed Dec 01, 2021 1:24 am I have a problem but first I apologize if I'm posting in the wrong place...
Emulator may not be compatible with ehide.device driver?
~ Stanislaw Lem
hardgb
Post by hardgb »
arkadiusz.makarenko wrote: Wed Dec 01, 2021 9:06 am
I'm suspecting the shapeshifter is not compatible with the ehide.device drive?
Because even with the overclock the shapeshifter worked on the A1200's IDE, it was just using the Shapeshifter's IDE that it didn't work.
hardgb wrote: Wed Dec 01, 2021 1:30 pm I'm suspecting the shapeshifter is not compatible with the ehide.device drive?
I mean at a hardware level the interfaces are pretty much identical. maybe @erique would have some thoughts?
hardgb
Post by hardgb »
terriblefire wrote: Wed Dec 01, 2021 1:32 pm
So it must be some configuration of the Shapeshifter itself... :roll:
I will analyze a little more
hardgb
Post by hardgb »
Wow!!!
Got it, here it worked.
I just went into the settings and changed SCSI.DEVICE to EHIDE.DEVICE and it worked.
Perfect! Thank you all for your help.
photo1638366649 (1).jpeg (142.93 KiB) Viewed 4439 times
supaduper
Post by supaduper »
Excellent well done fella. ehide.device for the win ! ;)
hardgb wrote: Wed Dec 01, 2021 1:59 pm Wow!!!
Nice. Where did you get the MacOS image?
hardgb
Post by hardgb »
terriblefire wrote: Wed Dec 01, 2021 4:20 pm
It's been a long time, I must have the links saved in my email. Can I paste the links right here?
Return to “TF360”
