Failing 1260
Avinitlarge
Failing 1260
Post by Avinitlarge »
I’ve been sent a 1260 that has failed twice, first time it was the cpu, sent it back to the customer and it failed again, this time it was the ram. My only thought was the regulator, it’s putting out 3.4v which it a touch high but still .2v lower that the max voltage of the chips. The board is one of the original ones, I think it was built by someone called mark, maybe, not sure.
Has anyone had anything like this or has he been unlucky?
It is fitted with this regulator
supaduper
Re: Failing 1260
Post by supaduper »
Those Buck converters work fine, many sold not one failed because of that, I don't understand your post? you say customer sent you a TF1260 but if I built the card why did they not contact me ?
Avinitlarge
Re: Failing 1260
I had a load of boards of his that I was working on, he sent it me to look at, I think it was just easier to send it to me. He isn’t unhappy with you, don’t worry 😉
It’s nothing you have done as it all looks sound, I think he’s just been unlucky.
