How to install IDE to CF adapter into Falcon ?
Sinis
Post by Sinis »
Hello all,
I just bought https://www.exxosforum.co.uk/atari/store2/#0036 and removed the IDE drive. Question: How do I attach the adapter to the chassis?
I thought the holes would allow me to attach it with a few screws, but I don't see any holes available for that.
How did you do it with this Exxos adapter? Drill the disk holder? And if so, what do you put as insulation between the chassis and the adapter?
Thanks in advance!
Re: How to install IDE to CF adapter into Falcon ?
Mostly people 3D print something to do the job.
EG:
https://www.myminifactory.com/object/3d ... ket-130808
Others may know better / other solutions.
Might be a bit crude - but I like to use double sided velcro tape on the bottom. It sticks well, is removable & shields it from the metal. The easiest way... But if I had a 3D printer I would do something with that. There are two types, the standard black velcro which has a lot of movement, or the white 3M picture hanging Velcro which holds solid, stiff as a board.
Another method is you can insulate the metal base with something, place the cf card drive down, then run two sets of zip-ties through the drive holes up and around securing it.
Alternatively automotive, double-sided foam tape.
I tend to use double sided RC servo tape, though a 3d printed adapter would certainly be an option.
Sinis
Post by Sinis »
Thank you for all your replies !
I'll try one and let you know :)
Glorfindeal
Post by Glorfindeal »
If somebody would print up a ide bracket with the appropriate holes for thee cf adapter they would easily make 10s of dollars. :D
smoore100
Post by smoore100 »
If you design one I will print it for you
Glorfindeal
Here are files for the ide drive bracket I found on the internet.
Atari Falcon 030 HDD bracket - 4619897.zip
(1.69 MiB) Downloaded 37 times
smoore100
Post by smoore100 »
Yep, I've printed those before - let me know if you'd like one and I'll get one printed for you
