Will the Exxos PSU work as a replacement PSU for a TT030?
Repairs & upgrades.
thesofa
Post by thesofa »
Not that I need one as yet but it's always good to know.
TT030 with Storm with 256 Mb Ram, Thunder with a CF drive and Lightning, HxC floppy emulator and one of Codekiller's magical Mono/Colour switchers, also 3 STS one has TOS1.0 AND 2.06 switchable with an HD drive, the other two are untested as yet, just bought for spares!!
Re: Will the Exxoss PSU work as a replacement PSU for a TT030?
I'm going to go out on a limb and say no.
I think the TT uses a PSU similar to the MSTE, and it is quite different to the standard ST that @exxos PSU replaces, and is more PC like.
No it won't. TT/MSTE PSU has negative voltage rails, higher currents, totally different physical size. If it was compatible then there would be guides etc
thesofa
Post by thesofa »
exxos wrote: Tue Nov 09, 2021 11:32 am No it won't. TT/MSTE PSU has negative voltage rails, higher currents, totally different physical size. If it was compatible then there would be guides etc
OK, thank you
Pity.
Re: Will the Exxos PSU work as a replacement PSU for a TT030?
Yeah, the TT power supply is essentially a PC-AT power supply in a smaller form factor.
