TF1230 Compatibility
68030 + SDRAM + IDE
I'm hearing some rumours that some demos don't work with the TF1230 (that do with other 030 cards). I've not been able to prove this myself so please list the glitchy ones here and i'll take a look.
List of issues : -
Nexus 7 (Runs Slow?) - Fixed
Control AGA - Fixed?
8 Bit Dreams
Re: TF1230 Compatibility
Post by 8 Bit Dreams »
Well, there is a Video on YouTube with a comparison of TF1230 vs Tsunami1230, some demos showing glitches, indeed, this may be caused by RAM timings I think:
http://eab.abime.net/showpost.php?p=151 ... stcount=29
8 Bit Dreams wrote: 30 Oct 2021 10:58 Well, there is a Video on YouTube with a comparison of TF1230 vs Tsunami1230, some demos showing glitches, indeed, this may be caused by RAM timings I think:
Unlikely. More likely cache settings.
Can this be reproduced on TF330? TF1230 is essentially the same card.
8 Bit Dreams
There is one thing that annoys me ATM:
the synthetic tests showing almost same results, but the difference is pretty big, Tsunami shows better Performance in Demos, this may be achieved by using FPU, will need to check are these Demos FPU optimised or not? If so - this wasn't a fair comparison, rather Tsunami promotion..
Another thing - TF1230 is able to use MMULibs and uFASTROM, this wasn't also mentioned for some reason?
terriblefire wrote: 30 Oct 2021 11:01 Can this be reproduced on TF330? TF1230 is essentially the same card.
need to check, have packed my CD32 away ATM...
Have built more than 100x TF330's and got not a single report of corrupted demos so may assume that TF330 doesn't have them...🤔
go0se
Post by go0se »
That video is amusing. Like the retro equivalent of a Tinder profile - going to a lot of effort to show all their positives and brushing the rest under the carpet! :lol:
Still, nice of them to perform some useful testing on the 1230 and provide feedback! :)
8 Bit Dreams wrote: 30 Oct 2021 11:16 Another thing - TF1230 is able to use MMULibs and uFASTROM, this wasn't also mentioned for some reason?
Because the guy that does that video is Edu's friend.... i'll leave you to judge after that.
chucky
Post by chucky »
none of those demos are FPU demos.. Nexus7 is a A500 only demo.
supaduper
Post by supaduper »
...and they overlook that Steve's TF1230 is open source..... the Edu board not so much :D
matt020
Post by matt020 »
The Nexus 7 demo gives the same result on the TF330 from my experience, yes.
I cant see the ball in this demo... all i ever see is the galaxy.. its kinda boring.
Return to “TF330”
Users browsing this forum: CCBot and 3 guests
