Falcon bodge wire problem, where to connect.
jacolover
Post by jacolover »
Have recapped my Falcon and a cap, 47 uf @16 volts connected at its positive end to U23, an SMD dip 8. Problem is what pin does that bodge wire connect to? It came loose and I can't find the pin to connect the bodge wire to. Thanks!
Re: Falcon bodge wire problem, where to connect.
Maybe post a image may help as I have no idea what bodge wire your referring to.. I don't recall falcons having any bodge wires even.
If you check in the motherboard photo forum you'll find some Clab Falcon threads I made which had some bodge wires around the SCSI area, I made some high quality close up shots.
