TF1260 programming - questions & discussion
Higgy
Post by Higgy »
Hi,
I've created this thread to hopefully keep the other threads clear regarding programming Firmware.
We really want to keep TerribleFire concentrating on Firmware, and not on our lamer programming questions ;).
So people can discuss programming on this thread and keep the other thread to bugs, experiences and findings.
(@terriblefire I hope this is preferred and ok, please delete if it's not what you want. Just trying to clear you from reading and answering guff)
Re: TF1260 programming - questions & discussion
This is fine... i want to keep feedback and "how do i do XYZ" separate.
matt020
Post by matt020 »
I would like to post here, as I have this week just purchased a Raspberry Pi Zero W (wireless) to flash my TF1260. I have never done this before, but I am able to learn and pick things up quickly.
I am going to use the guide published here, word for word....
https://linuxjedi.co.uk/2020/12/01/prog ... pberry-pi/
and I will report back on any hurdles, hic cups, speed bumps, or anything that wasn't covered in the how-to.
Aeberbach
Post by Aeberbach »
This method has worked for me but my reference was https://anastas.io/hardware/2020/09/29/ ... sprog.html
- and I think I used sysfsgpio_creator instead of matrix_creator. Anyway one of them works ;)
Danoo
Post by Danoo »
I use a cheap Xilinx Jtag programmer purchased from China and ISE Impact, approx. $30Aud delivered if I remember correctly.
It has always worked for myself, but I believe others have had issues with these units, so it maybe safer and probably cheaper to go the PI route.
Life is really simple, but we insist on making it complicated - Confucius
matt020
Post by matt020 »
Can I please ask about connecting 3.3v from the Pi to a TF card.
If 3.3v is connected, does that remove the need for the Amiga to be switched on?
If the Amiga is switched on and TF card installed, can 3.3v from the Pi be omitted?
Is there any harm in connecting 3.3v to the TF card and have the Amiga switched on?
trixster
Post by trixster »
matt020 wrote: Mon Sep 13, 2021 1:16 pm If 3.3v is connected, does that remove the need for the Amiga to be switched on?
Yes, the 3.3V from the Pi powers the cplds. The TF1260 can still be in the Amiga but make sure the Amiga is turned off.
supaduper
Post by supaduper »
you do not need to connect the TF to the A1200 you can program it outside the machine, just use the 3.3v on the pi to connect to the 3.3v on the JTAG on the TF
matt020
Post by matt020 »
Ok, and conversely, if the TF is in the Amiga, and the Amiga is powered on, the 3.3v line can be left out and not connected?
Higgy
Post by Higgy »
Damn message got lost.
Quick version - RPi sdcard got damaged with RPi alone.
Left TF1260 in Amiga. Powered Amiga on without CF installed. Did not use RPi 3.3v connection.
All good
Return to “TF360”
