TOS 2.06 and HD format option in Mega ST ?
HigashiJun
Post by HigashiJun »
Sorry if this question has already been answered somewhere in a previous post, but I am just wondering if there is a way to get the Floppy HD format option in TOS 2.06 with a Mega ST ?
is there an equivalent of the E6 jumper, such as on the STEs, or E7 switch as in the Mega STEs ?
frank.lukas
Re: TOS 2.06 and HD format option in Mega ST ?
Post by frank.lukas »
http://www.wrsonline.de/software/HDCOOKIE.LZH
It works with TOS 2.06 and TOS 3.06 but not with EmuTOS ...
... http://atariftp.czietz.de/pub/atari/Uti ... cc_2_2.lzh
This set the HD Cookie for EmuTOS.
HigashiJun
Thank you !
A big step forward.
Is there however a way to enable it permanently on the motherboard ?
Cheers.
troed
Post by troed »
HigashiJun wrote: Sun Sep 12, 2021 9:46 am Is there however a way to enable it permanently on the motherboard ?
No, not without adding some address decoding circuitry.
/Troed
HigashiJun
troed wrote: Sun Sep 12, 2021 10:25 am
/Troed
You mean something like a TOS decoder ?
troed
Post by troed »
HigashiJun wrote: Sun Sep 12, 2021 10:34 am You mean something like a TOS decoder ?
Slightly. The switches are addressable at $ffff9200 in TT and MegaSTE, so you would need to add logic to "answer" reads from that address with the right bitfield.
Also, since this is also the address for reading and writing to the extended joypad ports I'm not exactly sure how it's intermingled. Anyone?
/Troed
DoG
Post by DoG »
troed wrote: Sun Sep 12, 2021 10:46 am
Joy is read from databit 0-7 and switch/blob E0-E7 is databit 8-15 on STe schematics.
czietz
Post by czietz »
TOS 2.06 only reads those switches if running in on an (Mega)STE. Therefore, it doesn't suffice to decode that memory address on an MegaST! Your options are: a) patch TOS to set a _FDC cookie regardless (iirc, TosPatch has a corresponding option), b) run a program from the AUTO folder, as Frank already suggested.
HigashiJun
Nice !
Thank you all for all this interesting feedback.
I will start with the AUTO folder way and then give a try to the TOS patch option.
Cheers.
troed
Post by troed »
czietz wrote: Sun Sep 12, 2021 11:16 am TOS 2.06 only reads those switches if running in on an (Mega)STE. Therefore, it doesn't suffice to decode that memory address on an MegaST!
Thanks - that's no fun then ;)
/Troed
