Laser Printing with the ST
PeckPeekPoke
Post by PeckPeekPoke »
Hello Friends,
Any suggestions for laser printers compatible with both PC/Linux and with AtariST ?
Thanks ! :geek:
FOR GREAT JUSTICE. TAKE OUT EVERY ZIG
800xl+U1mb, STfm, STe, 030
Re: Laser Printing with the ST
Well, it would have to be a very old one with a parallel port for it to work with the ST directly. Otherwise you'd have to have something which could interface with the parallel port, take the output and then render it as PCL5, PCL6 or Postscript and send it to a USB or networked printer.
PeckPeekPoke
I think I've found something that will work: Brother HL-5240, it has both parallel and USB ports.
I'm not great at sight-reading, but I'd really like to be able to print some music out of Notator to hand to the minstrels in the event we can ever congregate in groups again.
You will need a printer driver to send the correct codes to the printer to write the image.
Is there a PCL5 driver on the ST?
PeckPeekPoke
stephen_usher wrote: Sun Aug 08, 2021 10:12 pm
Not yet. Any suggestions?
Return to “NOOB QUESTIONS”
