SIMM Socket to convert SIMM to SIPP
popcalent
Post by popcalent »
Hi everybody,
I have an Atari ABC 286/30 with 640KB of RAM. I want to upgrade to 4MB (the maximum as per the owner's manual). The computer has four 30-pin SIPP sockets. I've had a hard time finding SIPP modules that are not ridiculously expensive, so I resorted to buy four 30-pin SIMM modules with the intention to adapt them to the SIPP socket.
I've seen this product on the store: STE compatible 30pin simm socket £5 9 In Stock [0067]:
Will this take a 30-pin SIMM module and make it work on a 30-pin SIPP socket?
Thanks!
popcalent
My Computer:
Model: Atari ABC 286/30
Processor: Intel 80286 @8MHz
Coprocessor: Intel 80287 @8MHz
Total RAM: 640KB
Total HD: No HD
Floppy Drives: 1.44MB and 1.2MB
Re: SIMM Socket to convert SIMM to SIPP
Yes. I've swapped sipp modules with sockets a few times on STE machines.
popcalent
Post by popcalent »
exxos wrote: Sun Aug 08, 2021 12:30 pm Yes. I've swapped sipp modules with sockets a few times on STE machines.
Thanks for your response. I proceeded with the order. :dualthumbup:
My Computer:
Total RAM: 640KB
Total HD: No HD
tzok
Post by tzok »
You can also solder a so-called precision goldpin header to the generic SIMM module, and you will have a SIPP module. I think that is much less effort, and less risk to damage a motherboard while desoldering the DIP-like header for SIPPs.
popcalent
Post by popcalent »
tzok wrote: Sun Aug 08, 2021 8:24 pm You can also solder a so-called precision goldpin header to the generic SIMM module, and you will have a SIPP module. I think that is much less effort, and less risk to damage a motherboard while desoldering the DIP-like header for SIPPs.
Thanks for your response. I couldn't find any "precision" gold pin headers. All I found are the regular pin headers that are too big to fit into the SIPP socket. About desoldering the SIPP sockets... I was thinking about snapping the SIMM socket into the SIPP socket with no soldering involved.
My Computer:
Total RAM: 640KB
Total HD: No HD
popcalent wrote: Mon Aug 09, 2021 5:56 pm I was thinking about snapping the SIMM socket into the SIPP socket with no soldering involved.
That doesn't sound like a good idea.. if you're not up to the task, send your board to @Steve to fit it out properly.
tzok
Post by tzok »
popcalent wrote: Mon Aug 09, 2021 5:56 pmI couldn't find any "precision" gold pin headers.
https://botland.store/connectors-goldpi ... sis40.html
https://uk.farnell.com/samtec/ts-132-t- ... dp/2856631
popcalent
Post by popcalent »
exxos wrote: Mon Aug 09, 2021 6:14 pm That doesn't sound like a good idea.. if you're not up to the task, send your board to @Steve to fit it out properly.
Wouldn't the SIMM socket pins fit inside the SIPP socket in the same way the precision pin headers do?
This is what my SIPP sockets look like:
https://m.media-amazon.com/images/I/31u ... L._AC_.jpg
My Computer:
Total RAM: 640KB
Total HD: No HD
