STorm ST/Cloudy decoder with RTC compatibility
lrodriguezrullan
Will the STorm ST/Cloudy decoder with RTC work with the H5 in one of the 5V Bus IO ports? If so, may I leave the TOS ROM socket empty when using the STorm ST/Cloudy?
Thanks
Thanks
Re: STorm ST/Cloudy decoder with RTC compatibility
I would assume it will work.
lrodriguezrullan
I will try that. Thanks!
- alienkidmj12
did it work ?
Yes would love to know because I have one myself.
James
James
1088XEL, 800 incognito
Well I have mine installed, just waiting to confirm some traces, and then fire it up.
Has ANYONE used a Lightning/Cloudy or STorm/Cloudy or better yet a Lightning/Storm/Cloudy on the H5 board????
I do not have another machine to test my combo on at the moment, but I cannot get Lightning/Cloudy to decode (NO ROM ON BOOT)
I can get STorm Cloudy to boot to EMUTOS on the Cloudy.. but it cannot switch tos .. by hook or by crook.. nada.
with all three together, again.. I can get STORM to decode emutos.. but nothing else..
James
James
Remove the grey wire. The RTC should only have 4 wire connected.
EDIT: The wire is for software switching and is covered in the manual about STorm in the link I gave above. Sorry about that.
The lightning board is mounted upside down.
Yes I noticed that before I started it up DoG, as I noted on my build thread.
Seems my Cloudy is not working correctly. I can get all the functions of the Storm and the Lightning working, but the cloudy is stuck in one profile and will not switch or program.
James
James
