Creating bootable freemint harddrive in Hatari for use on a real ST(E).
General Discussion, STOS.
ube
Post by ube »
I'm doing this on my Mac but the instructions can be altered for Linux. Windows? No idea. :D
Stuff within code blocks are terminal commands, with pund/hash for prompt:
# command goes here
Create blank file:
# dd if=/dev/zero of=new.img bs=1m count=8192
Configure CPU and memory:
Machine Type.png (208.9 KiB) Viewed 6814 times
I’m going with 68030@32 in this case since it’ll take forever to extract the files otherwise.
Set up Hatari to use this file as ACSI HD Image (Settings -> Disks). Also add a gemdos drive for transfering, ~/Atari/a in my case. Copy stzip and freemint.zip to this directory.
DE Master HD image.png (84.45 KiB) Viewed 6814 times
Partition drive. There are guides for this on the interwebz. Just create 4 partitions (due to Gemdos-drive assigning G:).
Using stzip extract freemint.zip to C:. Add HD-driver (HDDriver is my goto, got several licenses) to your C-drive, if you’re not using EMUTOS.
Find your target media:
# diskutil list
Unmount your the disk.
# diskutil unmountdisk /dev/diskX
Clone disk:
# sudo dd if=new.img of=/dev/diskX bs=1024k
Eject:
# diskutil eject /dev/diskX
Pop the media into your real hardware! And boot!
Additional:
If you're setting up your environment you'll just need to clone the first partition of your drive, if you need to test it out on real hardware. Add count=<size of c: +1> to the clone command. Why +1? Just want to be sure that the full partition is written: more is more.
And I've added a 7z file of the st/ste freemint installation as well. This will unpack to 8GB. (Hopefully it'll work, haven't tried this exact one out.)
Edit: It worked. Oh, and the supplied image is WITHOUT HDDRIVER, get your own licenses.
Pasted Graphic 2.jpg (676.71 KiB) Viewed 6810 times
freemint_stste.7z
(3.8 MiB) Downloaded 242 times
!Message from: Moderator
@ube, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
master of the bare pcb
Return to “SOFTWARE”
