BOM
TF520 - 68020 Board
GadgetUK164
BOM
Post by GadgetUK164 »
Does anyone have a BOM for the TF520? Caps I am not so worried about, its the resistors I need to know the resistance of.
EDIT: Worst case, I will just work out where they are an go with similar to TF530. I suspect they are just going to be pull ups etc.
GadgetUK164
Re: BOM
Ah, it's OK - I see them on the schematics!
4K7 it looks like (for all)
All assembled and working OK =D Struggling to get any fast RAM working with it, but I am using a 25Mhz XTAL atm. Will drop to 20Mhz and see how I get on. The main thing is it works =D
If anyone else decides to build one of these, it uses the same schmitt trigger as the TF530. Caps - all SMD ones I went with 100nF. The two electrolytics - I just went with a 1uF and a 10uF (1uF nearest the CPU) - probably better having them the other way around. XTAL 7mm x 5mm 3.3v 20Mhz, and the usual 2.54 pin header and turn pin header etc. Nice simple board - doesn't take long to assemble!
Not very useful compared with at TF536 etc, but fun to build!
tOriman
Re: BOM
Post by tOriman »
Hi GadgetUK164,
Please read PM - I have a case for you (AtariST). Thanks.
regards
tOri
https://reversing.pl/ - SSL enabled site ATARI - Power without price and necessary elementsvarious varieties for Atari and not only - useful or not, but it's worth a look ...
http://atari.myftp.org
Return to “TF520 (OBSOLETE)”
