A600/TF536 with AmigaOS 3.2 no boot
Black screen. WIthout the TF536 it does boot. I tried stripping out the A604n module but no change in behavior.
Has anyone seen a boot with the 2021 3.2 ROM in an A600? I'd be keen to try the xilinx firmware you are using.
- Admin sponsor
Re: A600/TF536 with AmigaOS 3.2 no boot
Have you tried with all hard disks removed? Also try with caches disabled (CDIS) and tell me what you get.Aeberbach wrote: Tue Jun 29, 2021 10:40 am Black screen. WIthout the TF536 it does boot. I tried stripping out the A604n module but no change in behavior.
No hard drives (or floppy drives). With no TF536 I get the early boot menu with buttons down, or the kickstart animation if I wait.
With TF536 I still get black screen. No access to two-button gray early boot screen. There's some kind of video signal out because the monitor light is on but no image
I took some 30 gauge kynar wire, put it in the CDIS hole of the CPU socket and tied that to the GND pin on the JTAG header. No change - rainbow when powering on, nothing else.
- GadgetUK164
Swap back from 3.2 to anything else official - see if it boots then!
It boots OK with 2.05 (37.300).
The 536 won't boot on the A600 with 3.1.4 so I presume it's the same with 3.2. And even with the 3.1 it doesn't exactly work great.
- Admin sponsor
With the TF536 in the A600 i expect its looking for the correct gayle ID. People have reported similar issues with the Furia over on EAB.
EDIT: If i wanted to go down the nightmare route of supporting the A600 I would have made a dedicated card for it. Hence A600 is simply not supported by me because i have enough things to do already.
Totally fair - I’m only persisting because of the nice keyboard on it. My A1200 keyboard MPU can’t be far away then I can get the ReAmiga up and going.
I haven't had any issues with the TF536 on the 600 using 3.1, so I would stick with that if I were you
