4MB to 1MB of RAM in software?
General Discussion, STOS.
Cosmic Puppet
Post by Cosmic Puppet »
Is there a way to trick my Atari into thinking it has 1MB of RAM using software?
Cosmic Puppet
Re: 4MB to 1MB of RAM in software?
Probably programs in floppyshop PDL which do it. Of course you can set this easily on a ....H5 :lol:
Cosmic Puppet
Interesting thing just happened.
I booted the atari from TOS 1.0 disk.
Then viewed my disk containing the RAM lowering software and a folder containing MIDIDraw.
On the disk there where a few odd files with symbols under them (probably corruption) and the MIDIDraw folder appeared empty.
This disk was formatted in EmuTOS and is DOS compatible (meaning I can swap between PC and Atari)
I noticed last night that a disk formatted in TOS 1.0 isn't swappable between machines.
Anyway...when I reduced my RAM to 1MB the files on my floppy disk appeared normally and the MIDIDraw folder was populated.
Makes me wonder now if my RAM is implicated in some of my past issues (which are easily worked around in my main setup)
MIDI Draw still only manages the start screen and is frozen.
I wonder if this might be copy protection?
Not sure, but I thought TOS1.00 couldn't even read DOS disks ?
Cosmic Puppet
Probably should leave that rabbit hole @exxos :lol:
Peter's RAM program is great. I can run PHYSTOP.TOS in EmuTOS and it restarts my setup and reports the new RAM on the start screen.
Found out that MIDIDraw needs 1MB to run.
Cosmic Puppet
exxos wrote: Sat Jun 26, 2021 4:17 pm Probably programs in floppyshop PDL which do it. Of course you can set this easily on a ....H5 :lol:
Only just saw this! :lol:
derkom
Post by derkom »
exxos wrote: Sat Jun 26, 2021 4:32 pm Not sure, but I thought TOS1.00 couldn't even read DOS disks ?
IIRC (someone correct me if I'm wrong, as it's been eons), TOS 1.0 can read DOS floppies fine, just doesn't format floppies that DOS machines can read.
Darklord
Post by Darklord »
Think it was TOS v1.4 and up that allowed both...
HTH's.
derkom
Post by derkom »
Darklord wrote: Sun Jun 27, 2021 4:56 am Think it was TOS v1.4 and up that allowed both...
That's the cutoff I recall as well, but again I thought it was about formatting, not reading and that TOS could always read a MS-DOS-formatted floppy. Perhaps someone who knows for sure can set the record straight.
Return to “SOFTWARE”
