ST rev H & agranlund ram troubleshoot (solved)
Hey guys,
Just wondering about this, diagrom says memory test OK but yaart refuses to run and the desktop is corrupt:
czietz
Re: ST rev H & agranlund ram troubleshoot
Post by czietz »
Most likely: CAS1H and CAS1L swapped.
What are all the bodge wires for ?
@czietz - thanks m8, you were right :)
- Seems I followed the instructions correctly, but I think @agranlund might have either the MMU pinout wrong or his silkscreen wrong:
https://github.com/agranlund/STRam
MMU pins:
RAS1  = 18
CAS1L = 21
CAS1H = 22
MAD9  = 64
I did have CAS1L to 21 and CAS1H to 22 as described.
@exxos No bodge wires, I just routed the wires underneath the resistor legs to keep them neat.
derkom
Post by derkom »
Steve wrote: Tue Jun 15, 2021 11:28 am Just wondering about this, diagrom says memory test OK but yaart refuses to run and the desktop is corrupt:
FYI, the Atari Diagnostic Software and DiagROM are two different things.
@derkom thx ;0
Steve wrote: Tue Jun 15, 2021 12:23 pm - Seems I followed the instructions correctly, but I think @agranlund might have either the MMU pinout wrong or his silkscreen wrong:
MMU pins:
RAS1  = 18
CAS1L = 21
CAS1H = 22
MAD9  = 64
@exxos yes then the silkscreen on the 4mbstram board must be incorrect
Steve wrote: Tue Jun 15, 2021 1:16 pm @exxos yes then the silkscreen on the 4mbstram board must be incorrect
Yes that is the case.
PhilC wrote: Tue Jun 15, 2021 4:16 pm Yes that is the case.
It looks right to me tho :shrug:
