Need DB19 male right angle connex for Falcon mobo
Hey guys,
I know these things are hard to find but surely someone might have one they can sell to me? I have a Falcon with missing connector, I really would rather not have to bodge something together :(
Cheers
Re: Need DB19 male right angle connex for Falcon mobo
Are they not the same as in my store ?
@exxos I don't think you have male ones, from what I can tell.
Steve wrote: Wed May 19, 2021 8:40 pm @exxos I don't think you have male ones, from what I can tell.
oh right angle male, nope :( don't think I seen those anywhere.
sety
Post by sety »
I doubt you'll find one. The only options I can think of is to make one by soldering some 1mm copper wire pigtails to a normal male connector, or design a PCB to adapt a DB15 VGA connector to the Falcon board.
The latter could be turned in to quite an elegant solution if done right. There might even be room for some switches next to the VGA port. :)
BEST might sell them but not so simple to order from :(
Post by JezC »
The other option might be to fit a socket & then connect a short male-male plug into that...not elegant but it should work.
Cheers for the ideas guys, I'll be able to make something decent I hope :)
