Is it ok to program the Xlinx at this stage? I guess so but wanted to be sure it was ok the apply power without the CPU.
Starting to build my TF536
Avinitlarge
After ages thinking about it, I decided to bite the bullet, I ordered everything but forgot the CPU socket
Re: Starting to build my TF536
You don't need a cpu in the board to program it but the board will need to be powered independently from the programmer ie sat in the Amiga socket and the computer powered up.
Or powered using the +5V & GND pin of the power header.
Avinitlarge
Well, something isn’t right, regulator is hot and so are the ram chips. Removed the chips and the reg is cool. The chips don’t read short or even low
Are the RAMs the right way around?
A1200 rev 1B & 1230-IV 50MHz / CPC 6128 / CPC 464 / ZX Spectrum 48K / ZX81
- Admin sponsor
if the reg is hot then too much power is being drawnAvinitlarge wrote: Thu Apr 15, 2021 7:08 pm Well, something isn’t right, regulator is hot and so are the ram chips. Removed the chips and the reg is cool. The chips don’t read short or even low![]()
- Admin sponsor
Yeah the ram chips are on backwards... the small dot needs to match up with the white dot.
Avinitlarge
I noticed that as soon as I replied. All good now.
I can’t believe I did that, I’ve been working with electronics since 94, and it’s my job
I feel like I massive dick now
Out of curiosity what is that thing in the first picture? A huge soldering iron.. a press?
Avinitlarge
Honton HT R390 rework station.
