Failed Exxos PSU Install - Help?
Repairs & upgrades.
Soyale
Post by Soyale »
I received my Exxos PSU this week and tried to install it today. It failed in that no lights came on once I had it all hooked up. I (tried) to configure it for 110V using the guide on this site. In all honesty, I didn't find this install easy primarily because my electronics skills are limited once you go outside throwing PC components together. Perhaps a good place to start is making sure that I connected the right wires together. See attached pictures.
2021-03-24 23.27.37.jpg (329.21 KiB) Viewed 2668 times
2021-03-24 23.26.33-1.jpg (297.99 KiB) Viewed 2668 times
2021-03-24 23.26.23.jpg (294.16 KiB) Viewed 2668 times
2021-03-24 23.26.10.jpg (342.66 KiB) Viewed 2668 times
2021-03-24 23.25.51.jpg (240.94 KiB) Viewed 2668 times
2021-03-24 23.22.15-1.jpg (278.17 KiB) Viewed 2668 times
Re: Failed Exxos PSU Install - Help?
You have wired the mains switch up wrong... The black wire should be above the other 2 wires...
Soyale
Post by Soyale »
That did it! Thanks so much.
I had hoped the PSU would help with some of the stability / output noise issues I was seeing. The video output noise has been reduced considerably. I don't know about stability yet but either way, I know I have a high quality PSU for many years to come.
BTW Apologies for tainting your beautiful power supply with my meagre soldering skills. I've covered the connections with tape so no-one will ever know what a mess they are.
James
