getting low readings on 12V Falcon supply
Repairs & upgrades.
jacolover
Post by jacolover »
the -12V rail is down to -10.59 v and the 12V is 11.59, +-5V is good, fan spins up but the 12V is too low, any ideas? This is a Skynet supply with Chemicons so I haven't replaced any caps on it, maybe I need to? Would be good to have a schematic but that doesn't appear to be available anywhere, so any suggestions would be good, thanks!
frank.lukas
Re: getting low readings on 12V Falcon supply
Post by frank.lukas »
This is normal and good.
Yes as Frank said this is within tolerance and fine
frank.lukas
The + 12v from the powersupply has only a few milliamps and is not loadable ...
jacolover
Post by jacolover »
OK, but is that acceptable for the -12 rail, a -10.69 sounds awfully out of tolerance, thanks!
jacolover wrote: Wed Mar 17, 2021 10:17 pm OK, but is that acceptable for the -12 rail, a -10.69 sounds awfully out of tolerance, thanks!
There is probably no regulation on the 12V, only the 5V. 12V is just pot luck on winding ratios of the transformer itself. So "normal" could be 10V-14V etc.
jacolover
Post by jacolover »
Thanks exxos, I plan on using this supply with a Mega STe as they have the same connector and looks like the same voltage requirement, does that sound OK?
jacolover wrote: Wed Mar 17, 2021 10:50 pm Thanks exxos, I plan on using this supply with a Mega STe as they have the same connector and looks like the same voltage requirement, does that sound OK?
Falcon PSU's are nothing like MEGA STE PSU's... They are not compatible.
jacolover
Post by jacolover »
Thanks for the heads up, just looking at them I thought they were, good to know!
