TF536, device driver for the IDE controller ?
68030 + SDRAM + IDE
WoC
Post by WoC »
Is there any device driver for the IDE controller on the TF536 that can be downloaded from somewhere ?
alenppc
Re: TF536, device driver for the IDE controller ?
Post by alenppc »
It’s part of the ROM, look for A600 Gayle style scsi.device.
Edit: You can actually use loadmodule to load a patched scsi.device that you should be able to find somewhere on the net.
WoC
Post by WoC »
By ROM, you mean the kickstart ?
alenppc
Post by alenppc »
Yes kickstart rom, I edited the reply above to specify that you can also load it from floppy but it’s much easier to just upgrade to kickstart 3.1.
Using 2.0 makes no sense to me.
WoC
Post by WoC »
Thanks appreciated. Fixing to upgrade to 3.1 but not 3.1.4, finding the workbench installation disks (to buy) was not easy for 3.1
alenppc
Post by alenppc »
WoC wrote: Tue Mar 16, 2021 3:41 pm Thanks appreciated. Fixing to upgrade to 3.1 but not 3.1.4, finding the workbench installation disks (to buy) was not easy for 3.1
3.1.4 works fine too.
WoC
Post by WoC »
alenppc wrote: Tue Mar 16, 2021 4:01 pm
Are you 100% sure about that ? From what I heard, there are issues with 3.1.4 that isn't in 3.1
alenppc
Post by alenppc »
WoC wrote: Wed Mar 17, 2021 8:31 pm Are you 100% sure about that ? From what I heard, there are issues with 3.1.4 that isn't in 3.1
I've been using it since it came out. No issues. You need to have the OS installed, and can forget about booting from old floppies without having to swap disks to load libs, but that's by design.
PaulJ_2.0
Post by PaulJ_2.0 »
WoC wrote: Wed Mar 17, 2021 8:31 pmAre you 100% sure about that ? From what I heard, there are issues with 3.1.4 that isn't in 3.1
I have used 3.1.4 for the past year and wouldn't downgrade to 3.1
I haven't had any issues and its use of large partitions makes using large SD cards a breeze.
pipper
Post by pipper »
On Kick 1.3 and a TF530 I have successfully used this ide.device driver:
https://gitlab.com/MHeinrichs/AIDE
Return to “TF536”
