UltraSATAN clock utils don't work with EmuTOS: Have versions which do...
I found that the stock built versions of us_getcl.prg and us_setcl.prg didn't work under EmuTOS (or, indeed, PAK/3) so I've rebuilt them using GCC.
I had to modify the source slightly so as to use osbind.h and use st52 codes directly for the screen control but that's about it.
These work both under the 68000 and 68030 under all OS versions I've tested on.
- Cosmic Puppet
Re: UltraSATAN clock utils don't work with EmuTOS: Have versions which do...
Is this using EmuTOS from ROM? as my clock files work with emutos.prg (although the time does eventually drift a little)stephen_usher wrote: Wed Mar 03, 2021 11:26 pm I found that the stock built versions of us_getcl.prg and us_setcl.prg didn't work under EmuTOS (or, indeed, PAK/3) so I've rebuilt them using GCC.
Yes, from 256K ROM (and 512K TOS3.06 PAK/3). The original binaries worked under TOS 1.04 on the same hardware, when switched to use the 68000 processor.
Basically they weren’t seeing the UltraSATAN.
- Cosmic Puppet
Okay, thanks.stephen_usher wrote: Thu Mar 04, 2021 12:03 am Yes, from 256K ROM (and 512K TOS3.06 PAK/3). The original binaries worked under TOS 1.04 on the same hardware, when switched to use the 68000 processor.
DominoTree
Added native support this evening - no clock tools necessary
- Cosmic Puppet
Man, that UltraSatan case is a thing of beauty!
DominoTree
I found it on Thingiverse and I totally agree! I saw a post a couple weeks ago from the guy who designed it and he’s got a new and improved version but this one is already great!
Also was laughing to myself, I randomly decided to write this RTC support today and stumbled on this thread when I made a post about it - the universe is giving me timely ideas I guess
DominoTree
Finally wrapped up and submitted the initial patch for native EmuTOS support for the UltraSatan RTC
https://github.com/emutos/emutos/compar ... asatan_rtc
Wait, what? To be clear, you're talking about the original software that comes with the Ultrasatan?stephen_usher wrote: Wed Mar 03, 2021 11:26 pm I found that the stock built versions of us_getcl.prg and us_setcl.prg didn't work under EmuTOS (or, indeed, PAK/3) so I've rebuilt them using GCC.
Works fine here, out of the box with my Pak 68/3 equipped STacy. No issues that I'm aware of any
way.
What exactly are you seeing?
Thanks.
PS Or did you mean EmuTos on a Pak 68/3 equipped machine?
