PSU upgrade to STE for longevity and studio noise
Repairs & upgrades.
TheMilford
Post by TheMilford »
I'm new here so excuse the noob question... just starting to put my electronic recording studio back together and plan to make my STE the main synth sequencer. My STE with 4Mb is working great, but I know digital electronics can introduce noise into the power lines and adjacent equipment. I was wondering if the Exxos PSU upgrade and replacing all the 'lytics would be recommended as a preventative measure for these possible issues. Also seems like it will help to preserve the machine for future and keep it running cool and quiet for daily use. should I just go for it for peace of mind, or overkill?
Cheers,
DJ
Re: PSU upgrade to STE for longevity and studio noise
The exxos PSU's are designed for low noise, high output capability, cool running and many protection features. So if you want the best ;)
Though in terms of noise, the entire STE is a noise generator. They are prone to all sorts of audio issues on the DAC system, RAM etc. If you want the best low noise motherboard (and not need STE features) then invest in a H5 board.
In terms of issues being coupled back into the mains.. Thats a tricky one. Of course the toroidal transformer will isolate primary to secondary and only runs at mains frequency (most switchmodes switch the mains side so will likely introduce more noise than secondary side switching) , but it doesn't guarantee zero noise is coupled back. In that case (with any PSU really) if its a problem, you should look into mains filters and such.
TheMilford
Thanks for the prompt reply.
I understand there will be some inherent noise... but I was hopping the upgraded PSU would at least put me in a better situation to start, instead of getting halfway in to a project and start chasing down noise. I have total understanding that using a vintage piece of kit will have it's shortcomings or potential bugaboos... I use a bunch of old midi and pre-midi gear that are noisy as hell. You should hear how noisy the Oberheim DSX is when using their weird Parallel Buss. ;)
I plan to do a full cap job in conjunction... but other than that I prefer to use an original machine. The new board looks interesting, but may be out of my league at present.
Which of your cap kit replaces the el caps on the motherboard? I see a few different kits, but some seem to be for the actual PSU.
TheMilford wrote: Fri Feb 26, 2021 3:18 pm Which of your cap kit replaces the el caps on the motherboard? I see a few different kits, but some seem to be for the actual PSU.
I don't do motherboard recap kits only PSU ones. The only large cap replacement I do is this one. https://www.exxosforum.co.uk/atari/store2/#0090
Some users here a while back were selling MB recap kits, but they might have been for the Falcon.
The PSU will help with noise no end. Though If your doing audio on the STE then your inherently going to end up with some noise anyway. If it's for MIDI usage, then assuming your STE has all the metal shielding, then that will cut down on radiated noise at least.
TheMilford
Awesome! I think that it's basically enough... no audio on the STE, just as a MIDI composer/sequencer... I might eventually try to use the soundchip for sounds... but not quite sure how to harness that yet.
I can just order from Digikey or Mouser. I'll search and see what type/grade/series caps folks recommend. Any thoughts on this?
I mostly go with panasonic FR caps, A lot you may need axial types tho.. I have never looked into those. So you will probably need to wade through datasheets of ESR values to get the best ones...
@TheMilford if you need someone to do work on your STE I am available.
TheMilford
Steve wrote: Fri Feb 26, 2021 7:16 pm @TheMilford if you need someone to do work on your STE I am available.
Thanks, But I'm in the US. I'm not keen on shipping this thing. I've don a lot of electronics work, but not computers much. I've recapped a couple STFs and swapped chips, drives and PSUs. If I could find somebody in the NYC or upstate area I would pay them to do the mods and upgrades while I rebuild my studio though.
I just had a real funny idea, asking Louis Rossman of Rossman repair group to service it for you. He is usually working on state of the art computers so it would be a funny change for him :)
