I found a G4 Mac (Installed MorphOS)
I was clearing out my loft as part of my house move and came across a G4 Mac Mini in a box. Mac used to be my wifes until she upgraded.
So being a geek i grabbed a MorphOS CD from https://www.morphos-team.net and installed it... and well i'm v impressed. Seems to be AmigaOS on PPC for hardware that is less than £100. You can still get the G4s on ebay for pennies.
I really like.
Re: I found a G4 Mac (Installed MorphOS)
terriblefire wrote: Sun Feb 07, 2021 11:30 am I was clearing out my loft as part of my house move and came across a G4 Mac Mini in a box. Mac used to be my wifes until she upgraded.
I really like.
I have a 1.5Ghz G4 17" Powerbook, and I have to say that even with 1.5GB RAM MorphOS didn't run very well at all. Might have to give it another try, but the thing I REALLY want for my PBG4 is a new battery. Oh, and to work out why the right hand speaker doesn't work. Problem is, all the damn screws you need to pull out to get inside the damn thing!
Aeberbach
Post by Aeberbach »
Nice - what G4 mini do you have? There was a "secret" upgrade toward the end of the G4 mini's life. Instead of 1.42GHz the CPU was 1.5GHz, but the bigger upgrade was 128MB graphics instead of 64MB. This shows up in system information but not is not printed on the box.
You can also run OS 9 using a community-modified installer, it is the fastest way to run classic System. Everything but sound works, easily fixed with a cheap USB DAC (i.e. one made for Raspberry Pi).
I'm curious to know if there are MorphOS equivalents of most of the AmigaOS4.x software?
(e.g. is there anything to run?)
Aeberbach wrote: Mon Feb 08, 2021 8:58 pm Nice - what G4 mini do you have? There was a "secret" upgrade toward the end of the G4 mini's life. Instead of 1.42GHz the CPU was 1.5GHz, but the bigger upgrade was 128MB graphics instead of 64MB. This shows up in system information but not is not printed on the box.
I'll just use my macbook pro for MacOS>
alexh wrote: Mon Feb 08, 2021 9:45 pm I'm curious to know if there are MorphOS equivalents of most of the AmigaOS4.x software?
You can run all normal 68k software thats system friendly i believe.
In terms of native stuff...
I've had https://wayfarer.icu/ running no probs.
Also have quake going really nicely.
I recommend the SDK being installed right away.
Gives you access to gcc, make, cmake etc. As well as the gnu utils.
arkadiusz.makarenko
Post by arkadiusz.makarenko »
terriblefire wrote: Sun Feb 14, 2021 9:41 am I recommend the SDK being installed right away.
This is best selling point for me.
If MorphOS has decent editors and targeting 68k works out of the box, and you can hotswap sd or compact flash then it would be best Amiga development gear available.
~ Stanislaw Lem
TBH i just use VS Code and WSL. Amiga GCC and VBCC/VASM.
It gives perfect modern IDE for amiga development.
