Issue writing data on floppy (Write protected)
geogeo_28
Post by geogeo_28 »
I known this issue has already been addressed by Exxos and the pull-up fix on the data lines of the WD1772 but in my case this does not solve the problem.
My ATARI STe does not have issue reading disks but when I want to write data, I always end up with Write Protected Error. This happens when I start a copy, create a folder or at the end of a format. The most surprising is, even if I obtain this error, the TOS succeeds to format or create a folder.
I replaced the WD1772 without success, same issue. I checked the signal WP and no problem here.
I have the floppy mod from Exxos. When I use this mod, instead of having the write protected error, I end-up with `Data on the disk may be Damaged`.
My ATARI STe has a booster 8/32 MHz. Surprisingly when I switch to 32 MHz, I can sometimes format, write data, without issue.
This let me suspect that some noise make the signal WP appears on the bus.
I have the infamous DMA C025913-38, I probe the data lines no issue really.
But when I probe the RDY signal, by magic, no more write issue. I can format and copy data.
I suspect the small spike at the end to be the root cause of the issue.
What will be the best way to filter this signal?
Proud owner of:
- Atari STF (US).
- Atari STE (UK).
- Atari Falcon030 (US).
- Amiga 1200 (UK).
Re: Issue writing data on floppy (Write protected)
Odd.. Right at the start I think my first mod was to rdy if you check my DMA page on my website.. But the pull ups on the DMA bus solved it.. My 1.44 board has the pull ups , but also don't forget there's another lot of pull ups on the inverter connected to the 1772 in mandatory fixes..
geogeo_28
Post by geogeo_28 »
I am using a Gotek which has already some pull-ups on shugart bus + your 1.44 board (setup at double density for now) with the pull-ups on the DMA side?
I tried to replace the R303 from 1K to 1.5K without success.
One mod missing is the bus resistors on the CPU side but not sure if this is necessary with the STE Booster?
Proud owner of:
- Atari STF (US).
- Atari STE (UK).
- Amiga 1200 (UK).
The ste booster has bus pull ups on it already..
This is what I found but its done already https://www.exxosforum.co.uk/forum/viewt ... =23&t=1410
You should try a proper floppy drive to see if that works...
geogeo_28
Post by geogeo_28 »
I am kind of puzzle, because the Gotek works without issue on the Atari STF.
Same problem of write protected with the original floppy drive of the Atari STE and the High Density one.
I can read without issue, but cannot write.
In your thread you had the same issue than me and add an extra pull-up on RDY? I see also a small spike at the end. I am wondering if this is normal or not?
Proud owner of:
- Atari STF (US).
- Atari STE (UK).
- Amiga 1200 (UK).
Have you checked the 1772 data bus is connected to the DMA pins ? The RDY work was really old work, it was found that bit problems on the DMA/1772 bus was the cause.. possible broken trace somewhere ?
geogeo_28
Post by geogeo_28 »
I checked all the pins between 1772 and the DMA and everything look fine.
All data and address lines are fine.
Proud owner of:
- Atari STF (US).
- Atari STE (UK).
- Amiga 1200 (UK).
Well only thing is to try the original fix.. I think it was 390pf to gnd on rdy.
geogeo_28
Post by geogeo_28 »
Ok let me try this fix. ;)
Proud owner of:
- Atari STF (US).
- Atari STE (UK).
- Amiga 1200 (UK).
geogeo_28
Post by geogeo_28 »
Nop same issue with a capacitor of 400 pF on RDY and GND.
Here is what I have:
Here is what I get after formatting with the floppy board:
When doing nothing, I see the following noise, spike on RDY signal:
I probe each pin of 1772:
WD
DRQ
INTRQ
IP
WG
MO
CS
R/W
A0
A1
D0
D1
D2
D3, D4, D5, D6, D7 same
CLK
RDY
The signal RDY looks weird from my point of view. Seeing this spike at 2.3V when doing nothing.
DRQ, INTRQ, WG, MO seem a little too weak below 5V.
Proud owner of:
- Atari STF (US).
- Atari STE (UK).
- Amiga 1200 (UK).
Locked
