Great, thanks. Definitely helped me a lot with the pictures and the tip. I have a low res meter too and dug it out.
Located that the lowest value is the through hole at port #1, so carefully made a cut under the smd glue pin and another under Pin 52 of port #1, cutting that area out. Then linked pin52 of port#3 to the smd glue pin. Values are now ok.
It showed some sort of life briefly, however bombed out and diag cart picture also fell apart and started scrolling + going crazy.
Now back to white screen only but CPU is not halted anymore if no diag cart plugged in. With the diag plugged in it goes low. So still looks like some addressing/decoding problem.
more to come...
- File_001.jpg (83.45 KiB) Viewed 5864 times
- File_004.jpg (96.25 KiB) Viewed 5864 times
- File_005.jpg (173.24 KiB) Viewed 5864 times
