TF CD32 Riser Revision 3 Design discussion
TF CD32 Riser
arkadiusz.makarenko
Post by arkadiusz.makarenko »
@terriblefire
1. I was thinking if adding floppy header (most likely due to space on pcb - small custom requiring non standard cable) instead of porting FlashFloppy was solution most people would want?
FF will always be better and more up to date with all bells and whistles people can ever want, than my potential port?
So by providing all floppy signals this could be simpler solution?
If there is enough pins available?
2. Tidy up on Address Lines (?) and INTSIG lines - this could speed up cycles a lot, enabling potential Soundcard solution and direct data access.
3. Learn Eagle...
4. if not enough pins available check if 100pin stm32 would fit on PCB, and if package change is required - stm32H7 (460Mhz) series would be better fit.
~ Stanislaw Lem
Re: TF CD32 Riser Revision 3 Design discussion
arkadiusz.makarenko wrote: Sat Jan 16, 2021 1:05 pm @terriblefire
3. Learn Eagle...
1. The issue with a floppy connector is space and you can really only do a IDC header not a 23 pin D.. .because as you can already see the the 23 pin D on there already eats way too much space.
2. Yeah i can do that bit for you. It would be good to get that optimized. I screwed up A3 last time.
4. There are a couple of unused pins already on the ARM but what do you want the extra ones for? If we ditch the spi pins between the CPLD and ARM you can reuse them for an SD card. Thats your mass storage. The DAC headers are there for dev but maybe not useable so could be reused.
arkadiusz.makarenko
terriblefire wrote: Wed Feb 03, 2021 10:34 am
3. Learn Eagle...
I don't think there is not enough right type of pins available for all above.
For example if DAC is needed, we cannot use PA0-PA7 as PA4 and PA5 are only pins available for DAC, PB0-PB7 used by Data lines, PC port has missing PC5 on this package ...
I am planning to do some tests with DAC and transfer speeds to check if music card idea is achievable at all.
~ Stanislaw Lem
arkadiusz.makarenko wrote: Wed Feb 03, 2021 12:50 pm
Yeah i think if you want audio you will need at least a 16 bit databus... or we could do some weird DMA from RAM trick.. but thats not available with the current hardware.
I think floppy + SD card is doable with current setup. Audio was a mad idea anyways.
arkadiusz.makarenko
terriblefire wrote: Wed Feb 03, 2021 12:53 pm
I like the idea of audio, but before squeezing it in CD32 riser, I was planning to test it against A1200 clock port and more beefy stm32H723 550mhz microcontroller first.
~ Stanislaw Lem
arkadiusz.makarenko
OK.
I have done some measuring (on Rev2)
I wrote a program to pretend to send 8 bytes x 1048576 times, and it takes less than 10sec.
It looks like this, where only work is to insert data to buffer.
2021-02-04 20_11_44-Saleae Logic Software.png (10.54 KiB) Viewed 6913 times
Knowing that uncompressed data need 170KB/s and compressed MP3 with 320lbps is 40KB/s.. definitely data transfer Amiga->Riser will not be bottleneck.
Question is if it can be sustained when reads are from ide.
Edit.
And I did find out that I cannot do it too quickly (beginning and end of interrupt routine) I suspect it is because cpld doesn't detect rising edge if it goes up and down in the same amiga clock cycle.
~ Stanislaw Lem
arkadiusz.makarenko
Uncompressed 8bit mono 44.1k WAV.
16k chunks read from hdd and buffered in 64k buffer, then played via stm32 dac. Can be done, but loads of work.
Next step: 16bit stereo 44.1k That is 4 times more data to move.
arkadiusz.makarenko
Yup. I did send 16bit 44.1k stereo. Sound was distorted (I pushed straight 16bit to 12bit DAC), but played exactly the right lenght 6sec.
So yes data can keep up, now next step, decode mp3 on stm32 side.
~ Stanislaw Lem
arkadiusz.makarenko
I have mp3 decoder working, reading from fifo and outputing values.... it is not timed correctly and ouput is just rubbish but it decodes info, now need to understand what to do with it, as it is in stereo 16bit signed value.
Anyway I was happy to see this
Time to sync everything and check if there is enough RAM on stm32 to make it sound right.
~ Stanislaw Lem
arkadiusz.makarenko wrote: Wed Feb 10, 2021 10:22 pm I have mp3 decoder working, reading from fifo and outputing values.... it is not timed correctly and ouput is just rubbish but it decodes info, now need to understand what to do with it, as it is in stereo 16bit signed value.
sweet.. :D
I will find some time to do the eagle changes for you soon.. have house viewings right now
Return to “TF CD32 Riser”
