TF536 with 40MHz CPU
68030 + SDRAM + IDE
ninjafahrer
Post by ninjafahrer »
Hi,
is it possible to run the CPU on the TF536 with 40MHz, means just replacing the Oscillator?
arkadiusz.makarenko
Re: TF536 with 40MHz CPU
Post by arkadiusz.makarenko »
Firmware is fixed for 50mhz, so it most likely will not work.
You need to source 030 which will handle 50mhz better, if your cpu is unstable at this speed.
~ Stanislaw Lem
ninjafahrer wrote: 30 Dec 2020 21:44 Hi,
All bets are off if you move away from 50mhz. The logic and timing are fixed at this frequency.
alenppc
Post by alenppc »
I tried it but I would not recommend it. It only works with certain A500 motherboards (I think this only worked on a rev5 but not other revs), and there may be other side effects.
Return to “TF536”
Users browsing this forum: ClaudeBot, Google [Bot] and 4 guests
