WANTED: STFM cases
WANTED: STFM cases
Looking at the space between the keyboard and my CPU relocator board without the TF installed it's looking highly probable that the TF won't fit in there under the keyboard even with all the height saving I'm thinking of, so I'm looking to change tack a little and look into a replacement top for the STFM itself (with the keyboard blanked off) and making the keyboard external.
So, to do this I'll need two STFM case tops (one of which needs to be a long-button version) and a case bottom. The state of the rear of the lower case and one of the tops doesn't matter as they will be cut off.
So, wanted:
  • STFM long-button case top in good general condition. It doesn't matter if it's discoloured as it will be spray painted.
  • STFM case (top and bottom) in good condition from the front of the grill forward but rear (including the grill) doesn't matter.
